[Home]PCB Milling And Drilling With Cheap And Simple Height-Probing
LinuxCNCKnowledgeBase | RecentChanges | PageIndex | Preferences | LinuxCNC.org
Revision 2 not available (showing current revision instead)
INTRODUCTION
Please read about here: http://phk.freebsd.dk/CncPcb/
A solution using a Python code running on Linux, Mac OS and Windows can be found [[here]]. The solution was tested using Gerber files generated by KiCad? and Eagle.
A modified implementation based on the same idea is available at https://github.com/hase-berlin/pcbGcodeZprobing The basic principle is what Poul-Henning Kamp developed, implemented in Python as an import filter for LinuxCNC: The surface of the PCB is probed, the height profile is stored in G-Code variables and the milling moves are replaced with subroutine calls; the subroutine calculates the Z-height to follow the probed height profile. The implementation done by hase (Hartmut "hase" Semken) works with the G-Code generated by Eagle and probably others.
We will be updating this page documenting.
Workflow
    * export the Gerber files from KiCad? (select Plot Origin as Auxiliar Axis)
    * use pcb2gcode to convert Gerber files to Gcode, by executing on command line: pcb2gcode --verbose --zup=0.4 --zchange=1 --offset=0,010 --zdown=0,01 --max-deviation=0 --dpi=1000 --toolpath-smoothing-passes=0 example-Component.pho
    * execute etch_z_adjust.py: python etch_z_adjust.py
    * open the Gcode files with EMC2, run it and it will automatically probe and mill the PCB
This page is read-only. Follow the BasicSteps to edit pages. | View other revisions
Search:
Published under a Creative Commons License
